Results 1 to 8 of 8
Thread: Inflatable top ring leak repair
    Jun 2013
    Manitoba, Canada
    153
    Anyone ever find a proper repair kit for their constantly leaking top ring? I am looking for some material and the glue to totally recover the top ring and give it a second layer. Anyone find something that would work?
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Re: Inflatable top ring leak repair
    There are tons of Vinyl Pool Repair kits on the market. Make sure they have the underwater adhesive so you can patch your liner if need be too.
    You cut the patch to your liking, spread the adhesive on, press the patch on and wait for it to set up. Just be careful not to over inflate the ring on hot summer days. The heat will make the ring expand and the glue soften and they will pull loose. We did that and woke up to a third of our water gone and still pouring out one morning.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    Jun 2013
    Manitoba, Canada
    153
    Actually I ended up finding out that the top ring was done, the sun had damaged the vinyl beyond repair, so ended up buying a new pool at Wally World instead. Went for the 16' Ultra with a sand pump.
    Casey's Avatar
    SW PA
    10,453
    Good luck with your new pool xanadu!
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Good luck with the ultra. So far we love ours and we really will if the water will ever warm up a bit. Just make sure the ground is level before you set it up!
    Jun 2013
    Manitoba, Canada
    153
    It's up already, only took us 1-1/2 hours and the water is going in. Pad was already leveled.
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Hey! Nice pad! Looks just like ours.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Wow that was fast... Looks great....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
