Results 1 to 7 of 7
Thread: Taylor results, does everyone use 1 drop = 0.2 or 0.5 ppm
    May 2014
    St Louis, MO
    37
    Yesterday I added bleach, ran pump and tested for overnight test.
    FC 10.6
    CC 0.2
    This morning:
    FC 9.5
    CC 0.5
    Last night I tested using 1 drop=0.2 ppm
    This morning I tested using 1 drop=0.5 ppm
    I started the SWG this morning to maintain FC and continue Slam process. Which accuracy level does everyone use 0.2 or 0.5?
    24'x52" AGP 13,200 Gal Hayward Sand Filter w/ Matrix 2 speed pump Liquidator Taylor K-2006 Test Kit
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Taylor results, does everyone use 1 drop = 0.2 or 0.5 ppm
    1 drop is .5
    If you are SLAMING, there is no need for the SWG to be on. It cannot produce enough chloring to maintain FC at the needed level.
    Divin Dave,
    Mar 2013
    CT
    349
    Quote Originally Posted by Divin Dave View Post
    1 drop is .5
    I think pooley1 means what level do people use in the comparator tube? One level requires multiplying by .2 the other by .5.
    I use the higher level in the tube just because it's easier for me to see the color change with more water in the tube. I think that's .2 if I'm not mistaken.
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I use the small sample. It's accurate enough for normal use.
    If I was doing an overnight loss test, I might be tempted to use the larger sample.
    30,408
    For the guidelines we use here on TFP, there is seldom, if ever, any need for the .2 resolution (25ml). .5 ppm (10 ml) is all that's required.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You say you are slaming, that FC range looks very low, what is your CYA level?
    May 2014
    St Louis, MO
    37
    CYA is 33, so I was shooting for FC 12. Is 10.6 close enough?
