Thread: New Pressure Gauge
    Jul 2008
    Seacoast, NH
    252
    New Pressure Gauge
    PB opened the pool yesterday and replaced the pressure gauge. Base line on the old gauge has always been 18. Now the pressure is 15. Does the pump's baseline vary by gauge? i.e., is my new baseline 15 or is there something up and my pressure is 3 low.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: New Pressure Gauge
    If he also cleaned the filter, that may explain the lower pressure.
    PSI is PSI as long as all the flows and losses remain equal.
    Could also be though, that your old guage wasnt reading correctly.
    Whatever the case may be though, lower pressure is usually a good thing. Less wear and tear on it. A reduction of 3 psi is nothing at all to worry about.
    hope this helps
    Divin Dave,
    30,426
    Yeah, just use 15 psi as your new baseline....so a backwash psi of around 19-20 would be about right.
