Thread: New member, New TF 100 test kit, requesting advise
    May 2014
    Barnwell, SC
    2
    Really enjoying the site with all the info.
    Been running my pool for about two weeks now and the water is looking pretty good. I started with the chemicals recommended by my local pool company with the exception of using my chlorine bleach. Below are the results of the test from the TF100. Hope to get some advice as to where to go from here. I plan to abandon my pool company asap (there nice people but I have my own kids to send to college).
    CL 5
    PH 7.8
    FC 3.5
    CC .5
    TC 4.0
    CH 250
    TA 100
    CYA 30
    Also, one other thing. I bought a Hayward Aqua Trol SWG last year, but It is still new in the box due to being told that it was not wise to put it on my older above ground metal pool. I am okay with adding the bleach each day if necessary.
    Thanks in advance for all help and advice.
    James
    Doughboy 16 X 32 X 4 above ground with metal rails
    Vinyl liner
    1.5 hp pump motor and 18" sand filter
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: New member, New TF 100 test kit, requesting advise
    Hi, welcome to TFP! Looks like you are off to a fine start. Keep an eye on the pH and don't let it get any higher. Keep it between 7.2-7.8. I am curious about the CL 5. What test is that result from?
    Love TFP? Become a
    TFP Supporter!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    I'd go swimming if I was you. Those numbers are fine.
    Note that when you use the FAS-DPD powder test for chlorine, you don't need to use the chlorine side of the pH tester. You can already see it's not as accurate.
    If you get a bunch of people splashing tonight, expect to see your pH climb out of the safe zone. A littlle acid tomorrow will fix it up.
    Ain't it fun?
    May 2014
    Barnwell, SC
    2
    Thanks, So far I am enjoying the pool and the testing.
    The CL was suppose to be FC.
    I will pick up some acid tomorrow.
    James
    Vinyl liner
    38,274
    I am guessing the CL was the yellow OTO chlorine test right? No need to report that, if you do, I would not call it FC to avoid confusion.
