Thread: How many ounces in a pound of dry CYA ?
    vanessadickson's Avatar
    Jun 2012
    Kentucky
    61
    Smile How many ounces in a pound of dry CYA ?
    I know this is a dumb question, but I forget. Pool Math tells me the ounces, but dry CYA comes marked in pounds---so how many ounces in a dry pound of CYA/stabilizer?
    Thanks friends!
    Current results:
    Chlorine 3
    Alk 90
    CYA 60
    pH 7.6
    38,900 gal., UG, vinyl, SWG, Hayward w/T-15, 1.0HP pump, sand filter, Aquabot Turbo-T
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: How many ounces in a pound of dry CYA ?
    16, same as everything else
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    16 dry ounces in a pound. If you hover over the ounces on pool math, the cell at the top of the table shows pounds and ounces.
    Isolated Spa - 345 Gallons
    1 oz volume is about 1 oz weight. So, about 16 oz volume and weight per pound.
    Support the site
    Jun 2012
    Kentucky
    61
    Thanks guys! Nice tip, JVT!
    Careful with those measurements! A pound of feathers weigh more than a pound of gold.
    Rob B
    My $100 pool finally died after 6 years.
    Totally got our monies worth!
    Butterfly made me do it...
