Results 1 to 7 of 7
Thread: 2 days of heavy rain, glob of earthworms sitting under main drain
    Hi all. My pool is operating just fine, but today I noticed a whole glob of dead earthworms. They're pretty large, at least 4-6" each, and only in one of four of the main drains in the center of my pool.
    I'm assuming this is nothing to be worried about, but what do I do about it?
    ~12k gallon, cartridge filter, IG, plaster, 2hp Pentair Whisperflo WF-28, 150gpm filter
    Pics: http://imgur.com/a/HqaPq#0
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: 2 days of heavy rain, glob of earthworms sitting under main drain
    Skim them out and lob them into the planters
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I get about 10 or so every week in the bottom, more when we get heavy rains and the worms go on walkabout.
    Leaf rake gets them in short order. Nudge em with the rake, they pop off the bottom. Easy scooping.
    Isolated Spa - 345 Gallons
    Are the main drain covers supposed to be removable? Last I checked, mine didn't seem to come off very easily.
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by casastevo View Post
    No. If the worms are beneath the cover, maybe swim down with a hose and flush them out?
    What if I diverted all intake from the skimmers to the main drains in an attempt to suck them into the pump filter. Do you think that's worth a shot?
    Richard320's Avatar
    Jan 2010
    18,967
    Absolutely. I actually thought you'd tried that first.
