Results 1 to 16 of 16
Thread: New Guy Here
    May 2014
    Atoka, TN
    26
    New Guy Here
    Hi everyone, my name is Tommy and I am a new pool owner. I got a FREE AGP that is only 5 years old from a friend of mine. I will do a build thread once I get the pics uploaded.
    In preperation for the build I purchased a new liner, skimmer, foam cove, and was initally sold on the perma salt system from a local store.
    Since I didnt know much about it I did some research and decided it was not the best option for my family, we will be using chlorine. We have two children and I want the pool to be safe period. Luckily I was able to return it.
    The pool is in and level. I have turned off the water since it is just below the skimmer. I still need to hook up the pump and filter and decided to hard plumb now instead of later.
    Also, due to rain delays I have not backfilled the 2 ft yet so I want to rough in the pipes for two additional returns. I also need to bond it (still researching this one).
    Anyways, I just ordered the Taylor Complete FAS-DPD Pool Water Test kit K-2006 on amazon.
    Should I test the plain water first or is there any known chemicals I can go ahead and plan to add.
    Any advice you have, seeing my plans, are welcomed.
    Thanks!
    25,600 gallons
    33 Ft. 52 Inch AG buried 2 FT. Chlorine
    250 lb Sand Filter 2HP Hayward Pump
    38,371
    Re: New Guy Here
    Welcome to TFP!!!
    You certainly know that you need to add stabilizer (CYA) since there is none in tap water. You should also add some bleach in the evenings and brush it well to mix it to prevent algae from starting.
    The rest depend on test results.
    How much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    May 2014
    Atoka, TN
    26
    Re: New Guy Here
    Thanks. Yes I read those and others pertaining to new pools, etc. Should I go ahead and add bleach before I get the pumps hooked up?
    25,600 gallons
    38,371
    Re: New Guy Here
    Yes, that I why I said you should brush well, to mix the bleach in before the pump is running.
    You can also get the CYA in a sock and tie it to a noodle or something to have it start to dissolve as well.
    May 2014
    Atoka, TN
    26
    Re: New Guy Here
    Great, I will get that started today, Thanks
    25,600 gallons
    May 2014
    Atoka, TN
    26
    Re: New Guy Here
    Sorry, last question. How much bleach and CYA do you recommend I start with since I haven't tested the water yet? Thanks for the help. I will pay it forward.
    25,600 gallons
    38,371
    Re: New Guy Here
    Use PoolMath to determine how much you need.
    Instructions: http://www.troublefreepool.com/conte...ool-calculator
    I would add 30ppm of CYA and 2ppm of FC initially. As the CYA dissolves, then raise the FC level up corresponding to the FC/CYA Chart.
    May 2014
    Atoka, TN
    26
    Re: New Guy Here
    Is that 30 ppm 6.4 lbs? Checking my math.
    25,600 gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: New Guy Here
    Quote Originally Posted by TommyD View Post
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
    Yep, that's what I get off poolmath, 6 lbs, 7 oz
    May 2014
    Atoka, TN
    26
    Re: New Guy Here
    Sounds like a lot for a sock. Lol
    25,600 gallons
    Richard320's Avatar
    Jan 2010
    19,037
    Re: New Guy Here
    Use two, then. Hang the extra in front of a return.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Re: New Guy Here
    I can get about 2 pounds in a sock at once, maybe a touch more. But it dissolves in about 2-4 hrs when hanging in front of a return and squeezing it every once and while.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    38,371
    Re: New Guy Here
    No harm in rounding up either .... does not have to be exact. You eventually want to be between 30-50ppm. So if you find 4 lb buckets, just go ahead and add 8 pounds which should take you to around 37ppm.
    May 2014
    Atoka, TN
    26
    Re: New Guy Here
    Remember I have not hooked up plumbing yet. Should I wait and do that first?
    25,600 gallons
    Richard320's Avatar
    Jan 2010
    19,037
    Re: New Guy Here
    Yes. You want water circulation whenever you're adding chemicals so they mix well. Your arms will fall off if you try to brush continuously to keep things moving as long as it takes CYA to dissolve.
    4myBitsy's Avatar
    May 2013
    Milford, CT
    37
    Re: New Guy Here
    We installed a used pool last year and I love it. Good luck. You are in the right place for some amazing expert advice!
    AG 24' round 52" walls, 12,900 gal
    Proline 22" sand filter, Proline 1hp pump, vinyl liner, Taylor TF-100 test kit, TFPC
