Thread: Hello from Surf City USA.
    Mothara's Avatar
    Jul 2008
    Huntington Beach
    4
    New AGP pool, new forum member.
    Just joined and set it up today. It's about a third full right now.
    Read the forum first and then, with a budget of $500.00, bought the pool and accessories.
    Purchased the sometimes reviled Easy Set. Check
    Placed on a level concrete pad. Check.
    Replaced 1000 gal/hr pump/filter with 2500 gal/hr. Check
    Hooked up a solar heater. Check.
    Bought the TF - 100 test kit. Check
    Hit $501.38 without BBB and Algaecide.
    Now comes the fun part.
    JD
    Intex 15' x 36" Easy Set Pool
    Intex 2500 gal/hr pump/filter
    Sunheater 2' x 20' Solar heater
    TF - 100 Test Kit
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Hello from Surf City USA.
    Hi Mothara,
    Great first post! Check.
    Welcome to the forum!
    You're done SLAMing when:
    Quote Originally Posted by Mothara
    And the best part is you won't even NEED algaecide!!
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Cassiopeia's Avatar
    Jun 2008
    Tampa Bay FL
    46
    Welcome to the board! Have fun with your pool!
    15' ROUND, 52" AG
    Newbie at pool ownership!
