Results 1 to 13 of 13
Thread: flap on skimmer doesn't move stays inside skimmer...stuff on top of water.
    May 2014
    hope mills, nc
    18
    Not sure how to fix this problem any suggestions? Thanks in advance
    Above ground 24ft round 54 in deep 1hp 2speed Hayward power flo matrix pump& sand filter.
    38,428
    Re: flap on skimmer doesn't move stays inside skimmer...stuff on top of water.
    Well, why doesn't it move? What is it stuck on?
    Adamsaudio's Avatar
    Jun 2013
    Atl
    36
    Post a pic of it.
    24 ft Round Above Ground - 13500 gallons... Former Pool Frog user. Sand filter . Located just South of Atlanta
    May 2014
    hope mills, nc
    18
    Its not stuck on anything it just lays there doesnt move back and forth ill get a pic
    38,428
    Is there suction coming from the skimmer? If the weir is not moving, then there must not be any flow coming through the skimmer.
    May 2014
    hope mills, nc
    18
    It bounces up and down but not back and forth (in and out) I am pretty sure that's not the way it should function. But theres return water and its strong. Here's the best pic I can get
    mas985's Avatar
    Pleasanton, CA
    11,741
    The foam on the back is probably missing or waterlogged. That is what makes it float.
    Mark
    38,428
    Could be the foam like Mark mentioned, but that picture looks normal to me. It should not go in and out of the skimmer. It should just bob up and down with water flowing over it.
    May 2014
    hope mills, nc
    18
    Should it move all the time? It only bobs when ppl are in the pool maKing the water splash around? Is it possible to replace just the door? Or foam?
    mas985's Avatar
    Pleasanton, CA
    11,741
    If the weir rises back up when the pump is shut off, then it is working properly.
    Mark
    May 2014
    hope mills, nc
    18
    it stays flipped to the inside when pump is off
    mas985's Avatar
    Pleasanton, CA
    11,741
    So check the back of the weir. It should have a foam block. If it there, then it could be waterlogged. You can usually find a replacement on the internet or make your own.
    Mark
    Adamsaudio's Avatar
    Jun 2013
    Atl
    36
    If it's not standing up when the pump is off, you need to check and make sure it's in the guide holes at the base of each side at the bottom of the door. (mine is spring loaded) if it is and you can move it freely with your hand when the pump isn't on, you need to replace the foam so it will float back to the standing position.
