Thread: New pool pump recomendation
    I have a 28 x 54" round above ground pool that I need to replace the pool pump. The filter is a Hayward S210T sand filter. It has a 1 1/2hp pump now but I was wondering if a 1hp 2 speed pump would be sufficient. The pool is 20,700 gallons. I am looking at the Hayward Sp15922s pump.
    20,700G | AG | Vinyl | 62 GPM Sand Filter Hayward S244T| 1.5HP/2SP Pump
    38,295
    Re: New pool pump recomendation
    That is exactly the pump I was going to recommend
    Mar 2012
    Columbus, Ohio
    16
    If I were buying a new pump, it would definately be 220v powered. A little wiring change, a different circuit breaker, and outlet will give you half the operating expense.
    24' above ground, 2008 Esther Williams, 13,500 gallon, 200# sand filter, 1.5hp pump, bottom drains.
    38,295
    Quote Originally Posted by Sniper Racing View Post
    No it won't. It uses the same amount of power (watts). Power = Volts * amps. While the amps are 1/2 with a 230V pump, the voltage is double .... thus, same amount of power which is what you pay for.
    Thanks for the info.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Is your current pump bad, or just the motor, if it is just the motor you might consider replacing it with a 1.5 HP 2 speed motor and save some money.
    Ike
    p.s. most 2 speed motors are going to be wired 240V only, not sure how yours is now.
