Thread: Gravel level with respect to laterals: TR140C Penair Sand Filter
    I am installing a Pentair TR140C which specifies 275# of 1/4 to 1/8" dia pea gravel. What I find is that, when wet, this amount just matches the height of the top of the laterals. Is this the right level, or should be laterals be covered to perhaps an inch or should they be exposed? The sand will go above this obviously, leaving the needed free board of 13.5
    66,000 gal gunite private membership pool in NW Minnesota
    30,421
    Re: Gravel level with respect to laterals: TR140C Penair Sand Filter
    Pentair can verify the height. I chose not to use ANY gravel in mine ( 9 years ago) and it has functioned just fine. (it was a TR-140....not 140C) I don't think the exact amount is really critical but pentair should be consulted.
    patrick3229's Avatar
    Feb 2012
    258
    I have a follow up question what is the advantage / purpose of using a pea gravel layer with sand vs. using all sand with no pea gravel?
    Thank You
    Patrick
    www.inyopools.com
    30,421
    I don't want to hi-jack the thread from OP but it seems to be a way to get more flow directly around the laterals.
    I got an answer from Pentair, but in case others wonder about this I am providing their answer.
    They said that the pea gravel is used to aid/protect the laterals. Having it just slightly above the tops of the laterals is fine. This required 275# of 1/8-1/4" pea gravel, exactly what the spec called for.
    I have added pool filter sand above, 650# of it, which provided 13.5" of free board from the top inside of the unit to the top of the sand surface.
    In this configuration the unit is working well, with a pressure of 12 psi and flow rate of 110 gpm.
    Hopefully this information will be useful to another reader of this forum.
    Feb 2012
    258
    Thanks guys this is really helpful information.
