Results 1 to 8 of 8
Thread: Noob just trying to figure out this method
    May 2014
    United States
    2
    I have had a pool for many years and have constantly battled algae. I heard of this site from my brother and am trying to get this method going. My pool is an above ground pool with a vinyl liner. It's 30 ft diameter and 4 feet deep. It holds about 21,000 gallons of water. In the past all I used were the test strips (I know, embarrassing) for checking pH, alkalinity, free chlorine, etc. I have ordered the tf-100 test kit but it hasn't gotten here yet. I noticed a few days ago that my water was starting to turn green but doing a test (with the test strip) my chlorine levels were still high. So I took a water sample over to my brother last night (who already has the test kit) and these are the results he got: free chlorine 2.2, combined chlorine .8, so total chlorine is 3.0 (is how I understand it), pH 6.8, Total alkalinity 60, and, I believe, most importantly, CYA of at least 100 or more. I have a fresh water pool (not salt water) and from what I understand the CYA is what is killing me. I have already started to drain my pool (just cyphening it out with a garden hose) and have sent my wife to get gallons of walmart bleach. Other recommendations as to what I need to do to get rid of the algae and get my pool back to where it needs to be? I will add baking soda to increase pH. Any other thoughts or idea would be wonderful. Thanks. Brad
    38,274
    Re: Noob just trying to figure out this method
    Welcome to TFP!!!
    You are on the right track. The high CYA and relatively low FC is certainly at the root of your problem, so replacing water and getting bleach is a good start.
    Note that baking soda will not raise the pH, it raises the TA (which is fine). I would ignore the pH and TA until after you replace the water to get the CYA down and then do another full set of tests.
    How much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    After you have your test kit and the CYA lower, you are going to need to follow the SLAM Process to clear up the algae.
    Congratulations on actually taking the recommendation from your brother to look us up
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Get that brother of yours over there to test the water again as soon as it's been refilled and is circulating. You might not need any baking soda, depending on the fill water. Otherwise, it sounds like you've got it figured out. Lowering CYA, test kit ordered, mass quantities of bleach, local coach. I predict a speedy recovery! Take lots of pictures!
    May 2014
    Pasco, WA
    41
    I'm his brother and I've only been able to help him out because you guys have helped me out. I told him this forum was awesome! Thanks for chiming in so quickly.
    18k gal, AG, Sand filter, Aqua Trol SWG, Installed 5/2014
    Casey's Avatar
    SW PA
    10,435
    Two brothers joining TFP in the same month, same year, same test kits ordered... Wow, it's a beautiful thing! Now if we could only get Brad to update his profile and signature like his brother Matt did, we'll all be golden!
    May 2014
    United States
    2
    Quote Originally Posted by Casey View Post
    It's beautiful being brothers and being on the same site. How's my signature now?
    21k gal, AG, 22" Sand Filter, chlorine pool, 1.5 hp Hayward pump, 5/2008 installed, 5/29/2014 started using TFP and never going back!
    38,274
    That is a start ... although both of you could help by adding more detail: model and size of pump, model and size of filter
    30,415
    Add your city and state in your profile, too. It helps us by understanding the climate in which you live.
