Thread: Grand opening low cya
    Jun 2013
    Northern NJ
    123
    Hi all and happy summer season. I started tfp at mid season last year. At pool closing my cya level was 180. All winter I had nightmares about opening this spring and having to drain about47% of the pool. But over the winter the cya dropped to 30. Wow can't believe it! Has anyone experienced this? I was told by forum last year that I would have to drain to get the cya lower. Lucky or what?
    39,000 ig vinyl chlorine bleach borax and baking soda
    36,000 gal IG vinyl. Haywood pump and heater Hayward DE filter blue diamond robot. Hayward Aqua Rite SWG AQR-15
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Grand opening low cya
    Hopefully that CYA drop was due to rain and snow dilution, and not conversion into ammonia. That has happened a lot this year for some reason. Is the pool holding chlorine okay?
