Thread: chlorine question for pool cleaner
    Hi, I just bought my dolphin oasis z5 and have few questions. I read the website manual and it said use the cleaner in max 4 ppm chlorine. Normally I will keep my CYA in 40 and 7-9 ppm chlorine daily. Could i use my cleaner in this condition? Also when i do the SLAM (Shock), is there any problem using my cleaner?
    - NY Albany ~27000 water
    - In ground Vinyl 18' X 40' X 8' Deep Curved Roman End
    - Pentiar TA 60 Sand Filter
    - Pentair WhisperFlo 1HP Energy Efficient Full-Rated 2-Speed
    - 250K BTU Nat/Elec. Heater
    Re: chlorine question for pool cleaner
    Using the cleaner at your normal FC levels (7-9) is just fine. It is best to not use the cleaner at shock level.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    that 4 ppm number they publish is making the assumption there is no CYA in the pool which buffers chlorine
    May 2014
    Georgia
    22
    I might also suspect that its also a bit relative to the amount of time in the pool. Some of the dolphins have daily and weekly timers that I can only imagine is useful if you leave it in 24/7. Doing so is a whole different topic, but I'd suspect the plastics would hold up better if you had lower FC when "storing" the dolphin in the pool.
    CPO (15 years) 23K freeform Aqua Blue Mini, Omnilogic, Echostar, Colorlogic (2x12v), Jandy Laminars, Polaris 280, Dolphin M4
