Thread: Cyanuric Acid & the Sock
    Jun 2013
    Houston, TX
    23
    I just put stabilizer/conditioner in a sock and let the pump run 24 hrs. to bring my cyanuric acid level up (it's at 25). There is still chemical left in the sock and I didn't know if I should leave it in the skimmer until it all dissolves or remove it.
    DeeDee
    24Kgal/IG/Pebble/525sq.ft.CartridgeFilter/1.5 HP Pump/Built 2012
    Mar 2014
    Las Vegas
    288
    Re: Cyanuric Acid & the Sock
    It depends on your ultimate goal. If you are shooting for a level of 40 CYA, leave it in and squeeze the sock a few times when you happen to walk by. If your happy with your level of 25 (a little low for Houston area), take it out.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,971
    Sometimes it's really slow to dissolve. That's why we recommend the sock method. If you followed the bottle directions, all that stuff would still be sitting inside the filter undissolved, and if you had to backwash, it would all disappear and be wasted. Give it a few squeezes to remind it you want it to dissolve!
    Casey's Avatar
    SW PA
    10,427
    I never let it forget... I just keep it in my hands, over the return and get it dissolving into the water. Never had a problem doing it and it takes about 20minutes or so of constant manipulation to clear the sock. I'm impatient!
