Results 1 to 11 of 11
Thread: Should I SLAM?
    May 2013
    Souderton, PA
    104
    Should I SLAM?
    Everyday I put bleach in to raise my FC to 4 but each morning it keeps coming back as FC1 or 1.5 and CC .5. My PH is 7.4, ALK is 120. It stays the same pretty much everyday. I am concerned that the FC keeps going back to 1 or 1.5 everyday. Should I SLAM it? Pool is crystal clear.
    30 ft. round Aqua Leader agp with dished out center 23,800 gallons; 1.5 hp Hayward pro matrix pump; Hayward EC50 DE filter; solar panels; solar cover
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Should I SLAM?
    Question is,......what is your CYA level?
    May 2013
    Souderton, PA
    104
    Re: Should I SLAM?
    Cya 50
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Should I SLAM?
    2.5 to 3 FC loss in 24 hours is reasonable.
    You should be targeting 7 so that it never drops below 4.
    You could also run an overnight loss test to be sure there's nothing growing in the water.
    Apr 2010
    East Texas
    9,643
    Re: Should I SLAM?
    You should never let your FC get below 4 and your daily target should be 6 or better depending on how much sun/bather load your pool gets. I target 8 for mine.
    May 2013
    Souderton, PA
    104
    Re: Should I SLAM?
    It just keeps dropping back each night. My guess is I should SLAm it since there seems to be a big swing back to 1 or 1.5 each day. I just wanted to get others opinions before I did it. The low FC just does not seem right.
    Apr 2010
    East Texas
    9,643
    Re: Should I SLAM?
    You are not starting out with your FC...........HIGH...........enough is the problem.
    Makdaddy's Avatar
    Jul 2012
    Springfield Illinois
    119
    Re: Should I SLAM?
    CC of .05 is good
    how do you replenish the FC everyday? I have a SWG it runs 12 to 18 hrs a day depending on demand. it will maintain an FC of 8
    are you adding tablets everyday?
    --- Greg----
    24 x 54 Round Cozumel AGP with Grand Entrance Step 14500 Gal
    Running ntex Krystal Clear Saltwater System with E.C.O.
    A/G Cristal Flo II Sand Filter Tank w/ 2HP, 2-Speed Dynamo pump -Zeobest
    TFT Test Kit---Gorilla Floor and Foam Pool Cove--Half Deck
    Casey's Avatar
    SW PA
    10,453
    Re: Should I SLAM?
    Quote Originally Posted by woodyp View Post
    ^^^ This is the problem wiggledog. You have to keep a reserve of FC but by only targeting 4, you are depleting it before you ever really get it. As woody stated, you must go up to 7-8ppm and at the end of the day, you will have around 4ppm left over to keep algae away.
    May 2013
    Souderton, PA
    104
    Re: Should I SLAM?
    Thanks. I will raise it up tonight and then check on it tomorrow. I'll let you know what happens. Appreciate everyone's advice.
    May 2013
    Souderton, PA
    104
    Re: Should I SLAM?
    Last night I was going to put in 196 oz. of bleach, about 1 and a half bottles, but my husband got to it before I did and out in 2 bottles. This brought the FC up to 14. I just checked it this morning and it is down to 11. Numbers are:
    FC 11
    CC 0
    PH 7.4
    ALK 120
    CYA 50
    I am concerned about the drop in chlorine. Should I be?
