Thread: Plaster Stains
    May 2014
    Nazareth, PA
    1
    Plaster Stains
    Hello everyone. I have a SWG pool with a rock wall. I have a brownish colored stain streaming down the plaster across the whole wall. I assume the stain is from the leaching of iron out of the stone. What can I do to get rid of the stain? Thanks for your help.
    Jan 2013
    Houston, TX
    1,079
    Plaster Stains
    Welcome to tfp!
    The test to do on the stain is the vitamin c test ( hold a tablet on the stain and it will lift almost immediately.). If that works you can do the as ascorbic acid treatment. Instructions can be found in the how to or using the search.
    Edit changed orbit to ascorbic. Darn autocorrect
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Plaster Stains
    What he said ^^^
    Check out the picture in this thread closely. http://www.troublefreepool.com/threa...-Yellow-Stains
    Once the stains are gone, you'll likely need a sequestrant http://www.troublefreepool.com/conte...d-metal-stains
    30,403
    Re: Plaster Stains
    Are the stains above or below the waterline?
