Results 1 to 8 of 8
Thread: Pool lights in wrong place?
    May 2014
    Blue Point, NY
    2
    Hi there...just poured the concrete for a 38 x24 free form pool. We had told the contractor we wanted two lights on the 38' side nearest the house. We have a water view so we didn't want to be staring into spotlights. Came home today to find two holes cut out of concrete on the water side. So they face the house. In effect, it is exactly what we didn't want! The holes are big too, approximately 10" across. Is there anything we can do? What If we patch? Will that compromise the integrity of the pool? Or do we get light filters(this is the contractors solution.). Any suggestion would be appreciated.
    May 2014
    Blue Point, NY
    2
    Unhappy Lighting woes on new pool
    Help! We are under construction for a new 38' x 24' free form pool. It is concrete w/vinyl liner. The builder cut holes in the concrete for the lights on the wrong side of the pool. He should have put the lights on the house side but I came home to two 10" holes on the opposite side. So now I look at lights when sitting on the deck looking at the view of the bay. Is there anything we can do to fix this? Patch? Dimmers? Diffusers? This has definitely bummed me out. We have two sets of stairs. One in deep end one in shallow on the house side. He put the skimmers on the house side too.
    Also, I am supposed to have an 8 foot deep side. But it hasn't been dug that deep yet. Is this correct?
    22,553
    Re: Lighting woes on new pool
    Since you're still in construction, I'd have them patch the holes in the shell and cut new ones on the opposite side. Unless, of course, it's already full of water and the decking has been poured.
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    Re: Pool lights in wrong place?
    What was the builders reasoning for doing what you didn't want? I'm guessing you had this discussion with them before it all got started? Even though there are times as the consumer we want something a certain way, it's just not correct when we start talking to the pro's.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    That can be changed, even at this point, though it will take a bit of work to properly patch the holes. Talk to your builder and see what they are willing to do for you.
    MBG75's Avatar
    Jun 2013
    Long Island
    184
    Usually the lights shine into the steps to light them.
    25k IG vinyl SWG Haywood 4830de 1.5hp TF-100
    Jan 2011
    Richmond, Texas
    595
    You will hate having the lights shine at you. What was on the plans for the pool? If they show a different location I would make them fix the issue.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Nov 2013
    Miami, FL
    348
    Are you sure they are holes for the lights and not something else like returns? When they dug our pool, we had similar-sized holes all around the pool, but some were for lights, returns, vacuum hook-up, etc. Definitely talk to your PB!
    Swimming!: 19x32 IG rectangular pool, 22,500 gallons; 3' - 6.5'; open spa w/ 6 jets; raised wall w/ 1 sheer descent and 2 minijets, 2 color-changing LED pool lights, 1 spa light; Jandy 2 1/2 HP 2 speed Pump, Jandy cartridge filter (320 SQFT), Diamondbrite Cool Blue
