Results 1 to 8 of 8
Thread: Metal screws in sw pool
    May 2014
    Pasco, WA
    41
    My skimmer in my sw pool is held in place with metal screws. Is this normal? I've only had it up for a couple of weeks and they're already starting to rust. Any thoughts?
    18k gal, AG, Sand filter, Aqua Trol SWG, Installed 5/2014
    Jun 2011
    Long Beach, CA
    2,778
    Re: Metal screws in sw pool
    I would replace all the screws with stainless steel screws. A high quality stainless screw will not rust.
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    I agree with ping. I have a year old sw pool. My skimmer screws show no sign of rust.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    May 2014
    Merrimac, MA
    47
    If it does this to the screws, how will it impact the sidewalls on a vinyl lined pool with metal walls?
    26,700 Gal., 18x36 IG pool with Vinyl. 1HP Hayward Super Pump; Hayward DE3620 Filter; Hayward SAS; TFT-100 test kit; Dolphin Atlantis Cleaner.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    You could also use brass screws as they resist corrosion as well. If any expert chimes in that copper content of brass screws might be an issue though...
    Isolated Spa - 345 Gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by CLW42 View Post
    The gasket should keep the water inside the pool. There should be no contact at all between the walls and the water.
    May 2014
    Merrimac, MA
    47
    Okay, makes sense. But what if you get a hole in your liner? Will the 'salt' water corrode the walls any worse than 'regular' pool water? It's not a huge concern, but just something I thought about when I saw this post.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    I agree brass would work but I think stainless steel is stronger and it's not a place where I'd want to take a chance breaking one off.
    Solar Blanket, Well Water, Borax Added. 68
