Thread: Plumbing for slide
    Apr 2012
    Pittsburgh, PA
    15
    Plumbing for slide
    I'm looking to replumb the return lines in the photo for a slide. I'm thinking that my best bet would be to attach a three way valve to the closest return in the photo. That way I could shut off that return line when using the slide. Would that be best accomplished by inserting a three way valve on that return alone or is there a better method? I'm guessing that I would need to adjust the valve so it doesn't run in the typical inlet T configuration to make this happen. That seems like the easiest solution but I don't want to cause other problems. Thanks.
    25,000 gallon inground vinyl
    1 hp Hayward Superpump. Hayward Perflex DE filter
    Aquarite salt generator
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Plumbing for slide
    I would just add a T into your existing return line and put a conventional cut off valve on it.
    On a side point is that a T with a 1/2 or 3/4 inch fitting in the lower right corner of the photo?
    There are several ways to do it. I'd use a three way valve as original described. Both approaches will work, I guess it just depends on how you expect to be adjusting things most often.
    Apr 2012
    Pittsburgh, PA
    15
    I'm pretty sure that the T fitting that you see is related to the salt generator. It has some sort of wire that comes out of it and connects to that system but I don't really know it's purpose.
    Thanks for the replies. It sounds like I am on the right track with either option.
