Results 1 to 11 of 11
Thread: Grammy says hello
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    Grammy says hello
    Just wanted to let you know your website is wonderful! I had started to present a problem to your msg board earlier, but in the middle of posting it, decided to go out to my igp one more time to see what may be causing the water pressure issue, and noticed one of the "screws" on the pump filter basket wasn't tight. Once I tightened it, the water pressure came back and I am all smiles again! I am a 61 yr old grammy trying to maintain my one year old pool. I don't understand all the proper pool terminology but am slowly learning. Heck, I dont even understand the correlation between PH and Alkalinity, but i just learned Alkalinity is adjusted first, then check the PH! I think there are probably cheaper ways to treat my pool water, but until I learn what is what, I havent even attempted to sway from my pool people yet. They have been a big help to me so far. Again, thanks for this website and keep up the good work!
    18,000 gal, 18x32 IGP, vinyl liner, 3 to 5.5ft depth. One inlet/skimmer (Aqua Genie), one main drain. Hayward Pro Series Sand Filter w/filtration rate of 20 GPM/FT, Two-Speed Pentair Whisperflo 1 HP pump, Natural Gas Hayward H200 pool heater, Aquabot T2 (200 Series) Robotic Pool Cleaner (my best friend), Automatic Electric Pool Cover (2nd best friend).
    austinsmom01's Avatar
    Jun 2008
    Georgia
    163
    Re: Grammy says hello
    Hi Grammy! Welcome!!!!
    Even if you don't have a problem, feel free to post, comment or simply read. THIS PLACE IS GREAT!
    Happy swimming!
    15,400 gal. IG Gunnite
    1.5 hp Champion Pool Pump
    3/4 hp Century Pool & Spa Motor
    Pentair Automatic Chlorine Feeder
    Crystal Water Pool & Spa Cartridge Filter
    Polaris 280
    NCFlyersFan's Avatar
    May 2008
    NE North Carolina
    116
    Welcome to TFP Grammy !
    If you want to learn more about caring for your pool, I would recommend starting at the pool school http://www.troublefreepool.com/category/pool-school/. LOTS of good information.
    In any case, welcome and enjoy. These folks really know their stuff.
    13,000 gal AGP, Hayward X-Stream 100 sq ft cartridge, 1 HP Hayward Power-Flo Matrix Pump, all on two 6-hour on cycles per day. Baquacil to BBB convert.
    "It is necessary for us to learn from others' mistakes. You will not live long enough to make them all yourself." - Hyman G. Rickover
    Floater's Avatar
    May 2008
    Southwest OH
    111
    Welcome! Glad you found your problem.
    Around here, if you have a problem, it's likely that someone has had it before and can help to get you on the right track. TFP is definitely a great resource. Glad you found TFP
    ~_~ Sherry ~_~
    24' Round AGP, 13,500gal, 1.5hp Hayward
    Cartridge
    TF100 Test Kit BBB Baby!!!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Welcome! Glad you found us
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Grammy,
    Welcome to the forum.
    You're done SLAMing when:
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    Thanks for the welcome. After reading your pool school, forums, etc., i have decided to try to free myself from my pool store. I am very hesitant but willing to give it a shot. My robot is still working trying to clean up the "leftovers" from my latest pool store visit. I am tired of all the chemicals and money - all i want to do is swim with my grandbabies. I tried to order your test kit but it wouldnt accept my login/password, though i have no problem using it to login here. I guess I need the test kit first and foremost; can someone tell me why I am having difficulting logging in to do that?
    Jun 2008
    Georgia
    163
    Quote Originally Posted by h2ctpdjl
    If you've not ordered there before you have to place your item in the basket then continue to checkout. Then you click on register & checkout. That's where you'll put your info for your username and password. Then, the next time you order you'll just sign it.
    Polaris 280
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Welcome to TFP! As Anna has said, the kit site is not operated by TFP, so you'll need an account and password there as well.
    The maker of the kits posts here often though (duraleigh) so you are welcome to post any kit related questions you have as well.
    Congrats on taking control of your pool.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    Thanks. I realized that there was mention somehwere in the forums about them being a separate entity, so registered and got it ordered; in fact, it shipped already. Once it gets here, plan to start BBB immediately, with a little help from my TFP friends.
