Thread: First test with Taylor K-2006...Do I need to slam?
    May 2014
    St Louis, MO
    37
    I have not done anything to the pool this spring other than add some CYA, vacuumed, cleaned, run filter with SWG.
    FC 4.4
    CC 0.4
    PH 7.6
    TA 56
    CH 200
    CYA 33
    Do I need to Slam? The only # that concerns me is the CC of 0.4. I have not Slammed this year. Should I run overnite FC test? If that comes back good, should I bring CYA to 70 and do nothing more? Thanks
    Last edited by jblizzle; 05-28-2014 at 07:26 PM. Reason: Correct kit number in title
    24'x52" AGP 13,200 Gal Hayward Sand Filter w/ Matrix 2 speed pump Liquidator Taylor K-2006 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: First test with Taylor K-6000...Do I need to slam?
    Sounds like a plan to me. The FC should come up and hold better with more CYA in there.
