Thread: Calcium Hardness in Fiberglass Pool
    Cool Calcium Hardness in Fiberglass Pool
    Is monitoring calcium hardness important in a fiberglass pool? If so, why?
    Thanks!
    East TN
    13,000 gal San Juan Fiberglass Pool;SWG; GoldLine Pro Logic Controls
    Hayward Sand Filter; Hayward Max-Flo XL Pump;Polaris 380; Hayward ColorLogic LED
    Raypak Gas Heater
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Ideally Ch levels for a fiberglass pool should be around 200-250 to protect the gelcoat. What are your CH levels ? 😎
    Jeff
    Re: Calcium Hardness in Fiberglass Pool
    I thought it was only important for concrete pools because it pulled the calcium out of the walls of the pool. I never thought about the gelcoat. The lady at the pool store told me I didn't need to worry about CH because my pool is fiberglass. Right now it is about 150. I guess I should raise it. Thanks for the info!!
    East TN
    Raypak Gas Heater
    38,271
    Some gelcoats have calcium in them ... most do not.
    How can I find out if mine has calcium? Thanks!
    East TN
    Raypak Gas Heater
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Quote Originally Posted by creechy View Post
    Who knows? Contact San Juan Pools and ask. I think it's usually old pools that needed Calcium. You're almost there, anyway. CH will go up with evaporation. If you're worried, just use Cal-hypo instead of bleach to chlorinate until you reach 200, and then switch back to bleach.
