Results 1 to 7 of 7
Thread: hi ya'll from Arkansas
    Jul 2008
    Arkansas
    20
    Couldn't resist the subject line. I love the TFP forum. I've told all my friends. We just got an AG pool about 4 weeks ago. So far so good. I've learned loads from this forum. I'm sure it's already saved me from being ripped off a few times already. Thanks a million!!!!!!!!
    Ballparkmom
    16 x 33 x 52" AG pool, Hayward Vari-flo pump & sand filter, 1 skimmer, 1 main drain, 1 return, Zodiac LM3 24,000 SWG, Pool Rover Jr., 2 kids & a million toys
    Re: hi ya'll from Arkansas
    Hello Fellow Arkansan!!!
    26,000 gal liner IG pool
    Doughboy with concrete construction
    Full sun most of the day
    1.5 hp pump system
    200lb sand filter
    Fayetteville, Arkansas
    220
    Woooo Pig Sooooieeee!!!! Glad to see more Arkansans here and greetings from Fayetteville, glad you're here!
    20x40 30,000 gal IG Liner, Pentair II Sand
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Hi there!
    Welcome to TFP!
    Butterfly's Avatar
    South Carolina
    10,045
    Hi ballparkmom.
    Welcome to TFP!
    You're done SLAMing when:
    welcome to TFP! You found us at the perfect time: before you had a problem! Now you can keep the problems away!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Sep 2007
    Liberal, Missouri
    4
    Welcome to TFP. I no longer live in Arkansas, but still consider myself an Arkansan.
    25K gal, Vinyl, 18x36 Rectangle IG, 1.5 HP pump, sand filter with Zeobrite
