Thread: Laars 125 pool heater will not light
    May 2014
    United States
    2
    Hi I'm new here,this is my first post I have a Laars 125 natural gas, automatic ignition, pool heater that wont light. It wont make the sound like its trying to light. 2 years ago a service man replaced the pressure switch and left me the jump wire he used to bypass the pressure switch. I tried bypassing the pressure switch but it did not work. The unit is at least 10 years old. Any help would be appreciated,Thanks, Cavy
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Laars 125 pool heater will not light
    Welcome to TFP!
    I have experienced this same problem, but only when the heater gets drenched after a heavy rain. Once it dries out, it works fine. Any chance that it's happening to you under similar conditions or is that not a factor in your case?
    Casey's Avatar
    SW PA
    10,450
    Welcome to TFP.
    May 2014
    United States
    2
    No I'm not getting anything its not trying to ignite
