Results 1 to 12 of 12
Thread: Anyone using a pool pump timer?
    johnnysnok's Avatar
    Feb 2011
    South Jersey
    192
    Thinking of getting a pool pump timer, looking for pros and cons and any information on a manufacture if you feel they make a good product.
    Thanks
    Dough Boy 12' x 24' Oval
    Wedding Cake Steps
    1500 SF Timber Tech Composite Decking
    Video of my pool and retaining wall....Above Ground Pool Ideas - YouTube
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Anyone using a pool pump timer?
    How high tech are looking to get?
    A simple on-off timer or full-blown automation of multi-speed pumps and other accessories?
    -- Guy --
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I have a simple digital timer.... One for my peristaltic pump, one for my pool pump, and another for my solar heater....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    johnnysnok's Avatar
    Feb 2011
    South Jersey
    192
    I really only want a simple outside timer that will mount to the 6x6 under my existing outlet, that I can program and the pump plug then plugs into it.
    Wedding Cake Steps
    Makdaddy's Avatar
    Jul 2012
    Springfield Illinois
    119
    I have one like this worked all last summer and started up fine this year
    I do take it in over the winter.
    Make sure it matches the amp draw on your pump, Mine mounted on the post just like you mentioned
    I have a Brinks 42-1015
    http://www.walmart.com/ip/Brinks-42-...utlet/22257628
    --- Greg----
    24 x 54 Round Cozumel AGP with Grand Entrance Step 14500 Gal
    Running ntex Krystal Clear Saltwater System with E.C.O.
    A/G Cristal Flo II Sand Filter Tank w/ 2HP, 2-Speed Dynamo pump -Zeobest
    TFT Test Kit---Gorilla Floor and Foam Pool Cove--Half Deck
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    I'm going to install one today. This is what I get: Intermatic Weatherproof timer looks like a lot of people are using this kind. Make sure you get one that is designed for your pump HP.
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Now when using a timer on a intex pump....doesn't the gfi on the pump cord "trip" if the power cuts out?
    Intex Ultra Frame 18' x 52"
    Intex 3000 gph Sand Filter Pump, Intex Salt Water System SWG
    Hayward Thru Wall Skimmer and stock return line
    Two Hayward I lets
    Florida/Alabama
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,548
    Quote Originally Posted by kyles974 View Post
    Yes, mine did. I had to cut the GFCI off the pump cord. Of course, only do this if the entire circuit is GFCI protected, as mine is.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    I use the Intermatic Self-Adjusting Switch Timer on mine. Has worked really well and is quite easy to use. Mine is MDL ST01 series, but I have had it for the past four yrs, so assuming it has since been replaced by a different model. Good luck! Can't beat timer!
    18,000 gal, 18x32 IGP, vinyl liner, 3 to 5.5ft depth. One inlet/skimmer (Aqua Genie), one main drain. Hayward Pro Series Sand Filter w/filtration rate of 20 GPM/FT, Two-Speed Pentair Whisperflo 1 HP pump, Natural Gas Hayward H200 pool heater, Aquabot T2 (200 Series) Robotic Pool Cleaner (my best friend), Automatic Electric Pool Cover (2nd best friend).
    May 2014
    NJ
    12
    I'm using the Intermatc p1131 with the twist lock plug. I mounted it on the 4x4 right next to the receptacle and it works great. Got it for about $60 from amazon.
    13,000 gal 21' x 54'' Signature RTL pool, Hayward Power-Flo LX 1.5hp, Hayward S180T Filter, CL110 Chlorinator
    Jul 2012
    Seymour, In
    49
    I recently picked up a timer for my pump. I have the salt water generator plugged into its own outlet with power 24/7. I then have the pump on the timer which kicks on for 10 hours during the afternoon and evening. Here is what we got from amazon..
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    For the price, its hard to beat if it holds up for a couple seasons.
    24x54 ABG 15,200 gal, 22in Ecco Sand Filter, 1.5HP Ecco pump
    Jul 2011
    Bedford, NH
    67
    I use a $10 outdoor timer from Lowes, sometimes marketed for Christmas lights. I run 12 on, 12 off...works fine for me.
    18' round above ground, vinyl liner, 48" deep (flat), Confer Step1 steps. Approximately 7600 gallons. Waterways/Proline FC075 cartridge filter. 75GPM (71 minute complete cycle), 75 sq ft filtration area.
