Results 1 to 8 of 8
Thread: NEW Aquarite T-cell-15 indicating incorrect salt level (800ppm too high)
    May 2014
    Florida
    3
    I've installed a new T-cell-15 but it's indicating the salt level is 800ppm too high (it reads 3600ppm). It being too high initially was expected as I've read that as the old cells go bad, they start reading low.
    However, I've now had 3 water tests performed by two different pool stores and all indicate a salt level of 2800ppm. My old cell also indicates it's 2800ppm (at least for the first hour before it starts declining rapidly.)
    The manufacture keeps telling me all the water tests are wrong and my old cell is wrong, only the new cell is correct? They did also suggest that this cell may have thicker plates (which he said is "good") that may make it indicate slightly higher. Anyone ever have this issue?
    I find it hard to believe that all the water tests are wrong and this cell is correct. Not to mention they all coincidentally indicate the same reading of 2800ppm!
    38,251
    Re: NEW Aquarite T-cell-15 indicating incorrect salt level (800ppm too high)
    Welcome to TFP!!!
    Check that the cell size is correctly set to T-15 ... if you put in a smaller cell, it will report a higher salt level than reality.
    If the cell size is correct, then who cares 3600ppm is fine (I started mine even higher) and as long as it is working, it does not matter what the "true" salt level is.
    May 2014
    Florida
    3
    Mine is an older model; software version r1.33. So I can only use the T-15 and there is no ability to set to a smaller cell.
    It will indicate 4000ppm when the actual level is 3200. I guess I care that I'm spending $500 for something that doesn't work properly?? My old one worked fine and was accurate...
    38,251
    If the old one declined rapidly, then it was not working.
    May 2014
    Florida
    3
    Hence me purchasing a new one? What I meant by "the old worked fine and was accurate" was during the life of the cell, it's readings were relatively close to what the pool stores test indicated. There was never a 800ppm disparity!
    I've had 3 pool stores test my water and all indicate this unit is reading 800ppm too high.
    38,251
    I had a 600ppm disparity ... my SWG was reading lower than my drop kit ... still does. I do not worry about it as the only thing that matters is the SWG is happy.
    The SWG and the tests are only good to about +/- 400ppm, so you are within that range.
    May 2014
    Virginia Beach
    52
    Have you tried recalibrating your box?
    Forgive me if I am off, but I'm a newbie and my box has the same issue. It has been suggested to me that I need to recalibrate my box. While I was trying to accomplish this, my thermistor blew. New thermistors ordered and replacement panel as well. I will install the new panel and replace the old thermistor and save it as a backup.
    38,251
    Welcome to TFP!!!
    You can not really recalibrate the Hayward SWGs. You can override the average salt reading, but that is only temporary.
