Results 1 to 10 of 10
Thread: Replace pool light with cool LED color changing light.
    soupy8728's Avatar
    Sep 2012
    Temecula, CA
    66
    Cool Replace pool light with cool LED color changing light.
    Hi all,
    anyone have any advice on changing out my old plain pool light to one of those cool LED color changing lights? Thanks!
    ~Carl
    IG Plaster with raised spill-over Spa, ~26,000 gallons, Built 2001
    Cartridge filter
    Solar heated
    38,393
    Re: Replace pool light with cool LED color changing light.
    Depends on what kid of light fixture you have. I removed the failed blub and screwed in a new color LED bulb. Use a new seal on the fixture ... easy as replacing a light blub (almost )
    May 2014
    East Tennessee
    3
    I just replaced my ancient Hayward 500 watt Starlite with the ColorSPlash 3G and in my 20 x 40 pool the new light looks amazing. Also, it only uses a bit over 70 watts so that's a huge plus to my wallet.
    1994 36K 20x40 IG vinyl, S240 sand filter, Pentair WhisperFlo, Pentair Easytouch 4 w/ IC40 SWG, Raypak P-R336A gas heater
    38,393
    That is the bulb I got as well. It is certainly not as bright as a white bulb, and the reds do not travel far in water. With my long pool, certainly wish I had 2 lights.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I'm just replacing a niche light bulb myself. Mine is a pool that's new to me and it was broken when I moved in so I'll be replacing the gasket seal and the bulb. I'd say if you're going to put in an LED bulb, replace the gasket at the same time. $10 for a gasket to protect your $150-300 investment is money well spent. Also, test the whole assembly for leaks before turning on power to it. Assemble w/o bulb, submerge overnight, check for water intrusion in the morning. Then install and power up.
    Isolated Spa - 345 Gallons
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Advice? I wish with mine I could set the color and have it remember. Each time it turns on it resets, although you can manually toggle through the color by flipping the power quickly. I would consider that if I were doing it again.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    38,393
    The 3G remembers the color or program you set.
    soupy8728's Avatar
    Sep 2012
    Temecula, CA
    66
    I'm not sure what light is in there right now. Pool was built in early 2001ish....so I'm guessing that it would be as simple as opening it up and putting in the new LED bulb. I like the idea of one that "remembers" what you programmed into it. What are the costs on these things?
    Cartridge filter
    Solar heated
    38,393
    I think it was about $250.
    soupy8728's Avatar
    Sep 2012
    Temecula, CA
    66
    I see Leslie's has it for $299.
    Cartridge filter
    Solar heated
