Thread: Chlorine levels unstable
    Could someone please help?
    Opened AGP Saturday to green algae mess.
    Bleached the @#$% out of water and by Sunday it was clear, however, chlorine levels will not stay up. Added 3 gallons this morning, waited hour and checked at 10.5 ppm. (TF100) Checked 2 hrs later, .5ppm?!?!?!
    16X32 with 6 ft hopper
    Here are latest readings
    PH-7.8
    FC-.5
    CC-.5
    TC-1
    CH-120
    CYA- <20- at top of cylinder. water still clear enough to see black dot.
    Again, water in pool is still very clear and it is obvious there is some level of chlorine. Am I worrying too much?
    Re: Chlorine levels unstable
    You need to raise the CYA level or you lose all of your chlorine to sunlight.
    30,426
    Chlorine is a consumable item. It must be constantly replenished. Yours is getting consumed very fast for one (or both) of two reasons...
    1. You have no CYA in your pool
    2. You have organics (algae) in your pool.
    read "The ABC's of Pool Water Chemistry" up in Pool School.....that'll help you understand both things better.
    Oct 2013
    Chapin, SC
    1,141
    I'll vote for both!
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
