Thread: conflicting info on CH
    Nov 2012
    Ontario, Canada
    90
    My regular pool shop told me not to worry about ch level. every time my water test says my hardness is low they tell me to ignore it. they said that as long as my saturation index is in the acceptable range I'm fine (currently -0.8). Another shop however told me that the ch is important to prevent corrosion of the pool heater (they don't calculate csi).
    Which is correct?
    CH = 10 ppm but they said it should be 60-200.
    I have an ig sw pool with vinyl liner and gas heater.
    Re: conflicting info on CH
    The pool heater doesn't care in the slightest how low CH is. If CH is too high there could be a problem. However, some heater warranties require CH, even though it doesn't help at all.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Generally we feel that low CH is not important on a vinyl liner pool, although it may effect warranty issues for both your liner and your heater.
    Nov 2012
    Ontario, Canada
    90
    Both are 15 years old so warranty is not an issue. Thanks!
