Thread: Need to replace pump
    weatherillgrp's Avatar
    May 2014
    Cortez, CO
    26
    Last fall my Pentair 1 hp pump froze up. I called a local pool man and $190 later I had it rebuilt. It seem to run fine. Then this morning it froze up again. I have a call in to the pool man who repaired it in the fall and he will be over in about an hour. I think I will need to replace it with a new pump. I have looked on Amazon and see I can get a replacement for about $330. It is a PentairAir also and I think it will match up with my existing fittings. It now is all solid PVC joints and I am thinking about replacing it with couplers? Any advice? Also, my pool vac operates much too slow and I am thinking about going up to a 1 1/2 hp to create better suction and therefore speeding up the Hayward Cleaner. Thoughts?
    Also, any advice on single phase or two phase pump
    18K gal, IG vinyl, 1 hp single phase Pentair Pinnacle pump part 7-177474-01, Star-Rite Cristal Flow Filter model T-240BP-1, 266,000 BTU Raypac gas heater model PR266AENC, Coverstar electric safety cover, Hayward Navigator Pool Vac, Pentair model 300 Auto Chlorine Feeder( not using). TF-100 Test Kit. Built June 2007
    38,318
    Re: Need to replace pump
    Is there anything wrong with the pump wet end? If not, then you only need a new motor. And I would recommend upgrading to a 2-speed version to save yourself some $ on electricity.
    Can you be more specific with the model of the pump/motor?
    If you decide to go with a larger HP motor then you would also need a larger impeller to actually move more water ... I am not sure that is the problem though.
    May 2014
    Cortez, CO
    26
    Thanks for the feedback. Turns out I jumped the gun. The pump was okay. The problem was the startup capacitor. Pool guy replaced in in five minutes and it was up and pumping. Asked how much I owed him and he told me nothing, he would catch me next time. Small towns for ya. No service call fee and a neighborly gesture. I tried to pay him but he would not have anything to do with it. Offered him a 7up and spent the next 30 minutes just talking.
    nedchavez's Avatar
    Jun 2012
    Grand Rapids, Michigan
    111
    Sounds like a great pool guy to have!
    16' x 32' IG vinyl liner w/ hopper bottom (12,500 gal), Single-speed 1 HP Sta-Rite pump, and 300# Cristal-Flo sand filter, TF-100 test kit
    May 2014
    Cortez, CO
    26
    I have a suction side leak. I have tried the slow hose method and checked pump plugs, pump lid, ball valves and PVC joints leading up the pump. I watched to see if the bubbles in the strainer and saw no change. My next check might be the first joints below ground level. Prior to digging so anyone have any further suggestions about checking the above ground possibilities? I think it is getting worse. It starters last season late and I waited to this spring to address.
