Thread: Intex hose o-ring
    Jul 2012
    SE Minnesota
    137
    Intex hose o-ring
    FYI found replacement o-rings for the hoses and filter pump for the intex pools. I have an 18x48 easyset, not sure if the ultra frames have the same size but I'd guess most Intex are the same.
    It's a number 25.
    1-1/2" OD, 1-5/16" ID, 3/32" wall or
    38mm x 32mm x 2mm
    Purchased mine at Menards for $0.52 a piece, probably similar at other hardware stores.
    Intex Ultra Frame 26'x52"
    Intex 2,500 gal/hr pump with Unicel cartridge filter.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,008
    Re: Intex hose o-ring
    Good info. Thanks. Someone is bound to ask sometime before the end of the season.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    This would be for the 1.5 inch Intex hoses, not the 1.25 inch that the smaller pools use.
    Ike
