Thread: Return jets/eyeballs: decisions to make
    Mt. Airy, MD
    23
    I have a pool with at attached ~8' diameter spa. I need to replace the eyeball fittings on the spa, which are 1.5" inside fittings (press fit, no threads). What size eyeball should I get? I see there are different orifice sizes, and I am not sure what is best. My concerns would be creating excess back pressure, creating an uncomfortable amount of 'spray', but I don't want it to be weak either. I do know that when I run the spa alone, there is more back pressure on the pump than when I run the pool alone (which leads to my next question)...
    The pool itself has 2 returns, which are just 1" PVC. Is there any benefit to adding return eyeballs, or possibly some detriment?
    To summarize my questions:
    1. what size eyeball orifice for the spa?
    2. return eyeballs or not on pool?
    Dec 2009
    Virginia Beach, VA
    130
    Re: Return jets/eyeballs: decisions to make
    I'll give you my two cents on question #2, you'll have to find somebody else on #1.
    Return eyeballs in your pool allow you to create a flow of water in a certain direction so that your pool will skim properly. You either set it up so your water flows clockwise or counter-clockwise (based on the layout and features of your pool) so that you don't create stagnant portions of your pool where stuff just floats on top of the water and never gets pushed to the skimmer. So, in my opinion, if your pool is skimming properly (through the skimmers) and you don't have a problem with stuff on top of your water then don't worry about it. If you do have a problem, then the eyeballs should help.
    30,000 Gallon Inground, Vinyl Liner
    DE Filter & Pentair IC40 SWG
    Pentair Legend Platinum w/ PB4 Booster
    Pentair Kreepy Krawler Prowler Robot
    Jul 2013
    Clarksburg, MD
    93
    Let me guess, A&S built your pool.....I'm in the same boat, trying to find eyeballs that will fit into the 1" non threaded returns......not sure why A&S does this.
    18k gallon IG Sunstone Pearl pebble finish pool, Jandy Aquapure 1400 SWG, Jandy 1.5HP VS E-Pump, Jandy 60sqft DE filter, Jandy Legacy Propane Heater, Polaris 3900 Robotic Cleaner, TF-100 w/ SpeedStir, Anchor Mesh pool cover
