Thread: first intex pool
    May 2014
    nutley,nj
    7
    first intex pool
    I purchased a 14X42 ultra frame pool this year. My yard is level the previous owners had a pool set up in the same area im gonna use. Now I know I should put pavers underneath the legs for support but my problem is I cant dig down to make them level with the ground cause when they removed the pool they filled the hole with tons of tiny rocks. I was thinking about instead of the pavers to use the recycled rubber tiles from lowes or home depot for the leg support. Just want some opinions if u think they will be strong enough to withstand the weight of the pool for the summer.
    30,419
    Re: first intex pool
    Welcome to the forum.
    My guess is that won't be strong enough. I would suggest you dig the holes out with a pick-axe....hard work but doable.
    May 2014
    nutley,nj
    7
    I have 12x12 square pavers. If I lay them on the ground for the legs will the height difference cause a problem with the liner. I don't think digging down is a option with the rocks and tree roots.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Quote Originally Posted by joeyp3021 View Post
    The alternative is to use foam board the same thickness as the pavers and cut out the openings for them. Then everything will be the same height, flat, solid under the supports but soft where kids will hit with their heads when they dive despite your warnings not to.
    Browse around the forum and look for threads with icon, which means pictures.
