Results 1 to 11 of 11
Thread: Hydro Tools Solar Cover Reel
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Anyone using those? What are the reviews? It cost half of what I will have to pay at other stores. $141 for 30 ft solar cover. No body come even closer to that price.
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Hydro Tools Solar Cover Reel
    I am going to attempt to build one this year Pysiek... I reckon I'll be able to do it for about $70.00...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Pysiek's Avatar
    Apr 2012
    419
    Quote Originally Posted by laceygirl View Post
    What are you going to use for the pole?
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    A long piece of aluminium....
    Pysiek's Avatar
    Apr 2012
    419
    I cannot use that. My pool is 30ft diameter and my wife won't be able to lift it with the cover on. Will be too heavy.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    This will be a long square piece, its very very light....
    http://www.ebay.com.au/itm/like/2308...=true&lpid=107
    And because its square, its super strong...
    Pysiek's Avatar
    Apr 2012
    419
    Depends on the wall thickness.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I've built cubby house frames entirely from this material... Its so easy to work with.... I put everything together with plastic corners and right angles.... Too easy.... Light and strong...
    Jun 2013
    Manitoba, Canada
    153
    I paid $20 for a used one, with out the cover though. It was an awesome deal and works great. $141, and it come with cover and reel? If so, that is a good price.
    Pysiek's Avatar
    Apr 2012
    419
    Quote Originally Posted by xanadu View Post
    Only reel
    Jun 2013
    Manitoba, Canada
    153
    They usually go for more than that, so your doing okay for a new one. I would keep looking for a used one.
