Thread: Pump & Filter ?
    Jan 2014
    North/West Ohio
    13
    Pump & Filter ?
    How far away from the pool can you set your pump & filter? We have a 1.5hp single speed pump with a sand filter.
    Thanks
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pump & Filter ?
    There is no one right answer here, but 50+ ft suction side and return side plumbing paths are very common with inground pools.
    Ike
    p.s. flow restriction over distance can be partly mitigated by using larger diameter pipe
