Thread: Booster pump- PCC2000 not reaching full pressure...
    Oct 2013
    Phoenix area
    91
    So my pool is getting up to completion after major remodel - about 5 months with no pump/motor use. The filter pump had no issues starting up but the booster a no go. In fact the the propeller shaft seized up while trying to get this to prime. It's a challenger/pacfab 1hp
    I had the motor bearings, shaft and seal replaced this morning and back on the pump.
    With the pump back on, I couldn't get to prime. I left it to go to work. Got back to it after work and was able to get the water to build pressure with the lid under pressure. Thought I was good to go but after a while I noticed my heads not popping up. The pressure gauge on the PM6 shows up to 50 psi much higher than I am used to avg. 25psi.
    The PM 6 looks good the individual valves snap back and seat and the impeller and gear pieces move easily.
    The suction at my skimmer( 2 holes - 1 for filter and the other for the booster) is very little. I have no valves on this system as it's dedicated just for cleaning system.
    Not sure what to do next??
    Any ideas?
    Thanks in advance...
    13,000 gallon IG
    PCC IG cleaning system
    Pentair equip.
    Attached spa
    Dire need for surface refinish!
    Oct 2013
    Phoenix area
    91
    Re: Booster pump- PCC2000 not reaching full pressure...
    Anyone, anyone...
    13,000 gallon IG
    Pentair equip.
    Attached spa
