Thread: Opening Pool To Crystal Clear Water With Perfect Chemistry?
    Jun 2013
    East TN
    309
    How many people actually open up their pool and not have to do anything with it and have perfect water chemistry? I did. Thanks to the knowlege of this website.
    Just a little info on my success:
    Last Fall: Got my water chemistry right (pH, TA, CH, CYA).
    Last Fall: Added algaecide (Alkyl (50% C14, 40% C12, 10% C16) Dimethyl Benzyl Ammonium Chloride) and raised the FC level to shock level.
    Last Fall: Disconnected plumbing and winterized.
    Last Fall: Covered pool.
    Fall through Spring: Kept a check on my FC level. The FC level held steady all the way up until the weather started warming up and slowly took a plunge.
    Spring: I would peel back the cover and drop in a sump pump modified to circulate the water and add bleach to raise the FC level back to shock level a few times before time to open. I had to adjust my pH once.
    Now: Take off the cover, hook up the plumbing and turn on the pump with crystal clear water that was the same chemistry as what I left it.
    Anyone else have a Trouble Free time at opening?
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Opening Pool To Crystal Clear Water With Perfect Chemistry?
    Great Job easttn!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Good job ! Nice and easy when you close it up and open it right. 😎
    Jeff
    30,432
    There is a thread on the forum with others sharing their success stories this Spring. There are many of you who have a dead-on grasp of how this all works and it is a pleasure to see you post!
    Casey's Avatar
    SW PA
    10,461
    Great job!
    May 2014
    pennsylvania
    29
    I have a mesh cover, so its very hard with the addition of all that new water. Might look into putting a tarp over the mesh this fall to keep water out
    Moved so no longer pool owner, keeper of pool of family member
