Results 1 to 10 of 10
Thread: Black "oil looking" stains
    tgenre's Avatar
    Apr 2014
    Denham Springs, LA
    22
    HELP! I have a few black spots on my plaster that look like drops of black oil. I'm 99.9% sure I had nothing drip into my pool. I've had a couple of these for months that I ignored but now I have several that I think developed over the weekend. Is this common? Do you have any idea what it is? I've had the stains that come up with Vitamin C, but this is not that.
    FC 4
    Ph 7.8
    TA 70
    CH 525
    CYA 65
    Salt 3300 ppm
    Pump runs 10 hours/day with SWG at 50%
    18k Gallon gunite with Diamond Brite Bahama Breeze, Intellichlor IC20 SWG, Intelliflo Variable Speed Pump, Pentair Clean and Clear
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Black "oil looking" stains
    Can you scrape it off with a fingernail? If so, do that and rub it on a piece of white paper. If it's actually dark green, it's black algae.
    tgenre's Avatar
    Apr 2014
    Denham Springs, LA
    22
    Will not scrape. And thanks for responding so quickly.
    tgenre's Avatar
    Apr 2014
    Denham Springs, LA
    22
    Any other suggestions?
    Can you post pictures?
    Support the site
    tgenre's Avatar
    Apr 2014
    Denham Springs, LA
    22
    At work now...will take pics tomorrow and post
    Butterfly's Avatar
    South Carolina
    10,045
    What type brush do you use and how often do you brush the pool? Does brushing lessen/lighten/make any difference with the spots?
    You're done SLAMing when:
    tgenre's Avatar
    Apr 2014
    Denham Springs, LA
    22
    I do not brush often enough. I've never had anyone tell me how often I should brush (other than the initial twice daily brushing with fresh plaster). It is a Nylon (I think) brush. I probably brush the pool a few times a month, to be honest. The spots have actually lightened (although they wouldn't scrape with a fingernail or respond to vitamin C). They are still visible, and I have some that have been there for a while in the deeper end - those are still dark. I'm not sure about the metal content in my water, as I've not had a pool store test my water since being a TFP member!
    Butterfly's Avatar
    South Carolina
    10,045
    Brush recommendations:
    Nylon is for vinyl, fiberglass, tile, and plaster that is less than one year. (Plaster includes any exposed aggregate and marcite finish, btw!) Combo brushes are for older plaster. All stainless are for algae (very stubborn green algae and also the ONLY brush for black algae.)
    You CAN unscrew the Wall Whale from the nylon brush it comes with and screw it on a combo brush if your plaster is over a year old. Newer plaster is really too soft for anyting other than a nylon brush.
    Try rubbing a trichlor puck on the stain, or let it sit on the stain for a minute or two and see if it lightens.
    It would be good to brush the pool once a week. Most of us probably do not brush often enough.
    tgenre's Avatar
    Apr 2014
    Denham Springs, LA
    22
    Thanks for the education. My plaster is 6-7 mo old, so I'm good with Nylon brush only at this time (I just need to use it . I'll try to get some trichlor tabs and see what happens.
