Results 1 to 12 of 12
Thread: pump ran 6hrs with no water
    Feb 2014
    Houston, TX
    161
    I set my pump to waste since it was raining and i manually drained my pool a few inches. Long story short it ran for 6 hours with no water. I leave the skimmer open all the way and the main drain half open.
    I checked this morning immediately after seeing the water right below the skimmer line. I turned it on briefly after closing the skimmer and opening the main drain. I saw no water coming out.
    What am I in here for?
    Century B129, 3/4 HP, 1.5 SF,
    In-ground gunite 17,400 Gal, FNS plus 60 DE Filter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: pump ran 6hrs with no water
    What exactly is the pump doing/sounding like?
    Jan 2013
    Houston, TX
    1,079
    Does the pump try to prime when you turn it on? Any action at all?
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Feb 2014
    Houston, TX
    161
    So it sounds like its trying to prime. I set the multiport to closed and open the pump and add water with a hose. It seems to suck water and it fills up but then it loses its prime
    I dont know how to prime it
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,983
    Set the multiport to filter and make sure the skimmer is full. Fill the pump basket with water and close it. It should catch in twenty or thirty seconds.
    Feb 2014
    Houston, TX
    161
    It seems to have worked thanks everyone
    Feb 2014
    Houston, TX
    161
    The pump does not lose its prime but it is having small issues. The pump has very little air inside (very tiny bubbles). Once every 10 seconds I see a large gush of water come in through the t slot/3 way connection, which results in bubbles but they instantly disappear.
    The reason I say gush is because that is what it sounds like. Any advice?
    Jan 2013
    Houston, TX
    1,079
    Have you bled the air out of the filter?
    When a pump runs dry it gets very hot. Many of the plastic parts deform when they get hot, resulting in leaks. You might be lucky and have an end result you can live with, but chances are the main pump body needs to be replaced.
    Feb 2014
    Houston, TX
    161
    Karma, I did bleed out the air in the filter.
    Jason, are you saying I should replace my pump housing and keep all of the interior components (excluding seals,ect)? The previous home owners purchased it in 2012 I believe.
    You may need to do that, or maybe not. It depends on how much it deformed. After 6 hrs running dry it is unusual for it to be usable at all.
    Feb 2014
    Houston, TX
    161
    Thanks, I will open it up after summer. I dont wanna hear the wife!
