Thread: Pinhole leak - Pac Fab Challenger
    Jan 2013
    Houston, TX
    1,079
    age is catching up with my pump. It has developed a pinhole leak in the impeller housing. I'm going to try to squeeze another season out of it, any recommendations on what to patch it with (JB weld, epoxy, etc.).
    If not I'll just order a new housing @ roughly $100.
    Thanks!
    Chris
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    30,419
    Re: Pinhole leak - Pac Fab Challenger
    I would try an epoxy (jbweld or any other 2 part epoxy) but see if you can get it on the INSIDE.
    If it is a hairline crack, I would cut a v-shaped wedge on the inside of the crack so the epoxy can get a good "grip" and have some depth.
    If you are feeling particularly handy, drill a hole large enough to drill out the crack, then epoxy a piece of plastic on the outside of the resultant drilled hole with plenty of overlap. Give that 24 hours to cure and then go inside the housing and fill the hole with epoxy.
