Results 1 to 17 of 17
Thread: Test kit question
    Babylovestoys's Avatar
    Apr 2014
    Shreveport,La
    17
    Test kit question
    My husband & I had a discussion as to wether reagents in my Taylor K2006 test kit should be shaken or not before using. So I called Taylor Industries this am and talked with a very nice gentleman in the tech department. He confirmed that the reagents should not be shaken as suspended air may alter the test validity.
    He was asking about my pool & I shared about my Having a Swg but that if my free chlorine was to low that I would add a household bleach to boost my level and then increase my swg percentage to keep it there.
    Well, he strongly encouraged me NOT to use household bleach because it has too much TDS In it which will require draining. I explained that I didn't use products that add to my CH or CYA but he did not seem to "get it." Had he been pool schooled?
    Pool size: 17x33'4 water surface area: 591 sq ft. Depth: 36 to 7 ft. 23,300 gallons.
    IG. Gunite pebblefina with travertine coping. 18 inch travertine trough waterfall. 2 deck jets I aerator . Aqualink Z SWG. Auto floor cleaner PCC 2000. Jandy stealth variable speed pool pump, cartridge filter and never line valves. Auto fill.
    Taylor k2006 test kit.
    Aug 2011
    Southern California
    188
    Re: Test kit question
    When he mentions total dissolved solids he's not being specific to CH or CYA being in your bleach. It is in reference to everything else in your container of bleach, not including the chlorine itself.
    I've heard this before myself, but if I'm not mistaken, chlorine has TDS as well. Now does bleach add/contain more? That I'm not certain of.
    Jan 2013
    Houston, TX
    1,079
    he had been pool schooled.
    TDS doesn't really mean anything in terms of chemistry. The important part is WHAT (CYA and CH) dissolved solids are in your pool (bleach adds neither). You seem to have a good handle on it
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Apr 2014
    Shreveport,La
    17
    Yes, Hawk,he was referring to TDS in my household bleach. Thanks, Karmabiker! I meant he has been pool stored in the above post. Obviously, he hasn't been pool schooled! Lol. I was just surprised at his aversion to household bleach!
    Aug 2011
    Southern California
    188
    Quote Originally Posted by Babylovestoys View Post
    In this quote, can you explain how TDS has any relation to CH or CYA? And in which context did CH and CYA get associated with TDS? Was that by him or you?
    My understanding of TDS is that it includes EVERYTHING in your water, but not the water. Everything adds to it. The question I would have is does a gallon of bleach have more total disolved solids than a gallon of chlorine?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    TDS is to fruit as CYA is to banana. TDS is a general term for ANYTHING that's dissolved in your water. CYA is a specific part of TDS because it's dissolved in your water. So is calcium (CH). So is salt (NaCl), which is what is most of the TDS in household bleach.
    Asking someone if they want a piece of fruit will ALWAYS get you a return question: "What kind?" Some people love bananas but hate strawberries.
    Some pools need calcium but don't need CYA. It's what kind of TDS that's important.
    Isolated Spa - 345 Gallons
    Apr 2014
    Shreveport,La
    17
    In my conversation with the tech at Taylor industries, he said I should not use household bleach because there is approx 8.5 percent bleach & 93-96 percent "other" listed on the label, which includes TDS. He said I "should use calhypo, lithium or only liquid chlorine from pool store."
    I explained I didn't want to add any more calcium to my pool water or any more CYA which I was getting through pucks.
    Hope that clarifies the context of our conversation.
    Jan 2013
    Houston, TX
    1,079
    Quote Originally Posted by JVTrain View Post
    Exactly correct!
    I like the fruit banana reference.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Also the vast majority of that other 93-96% in bleach is WATER
    Apr 2014
    Shreveport,La
    17
    I thought about that too but I wasn't sure. I am still learning from this great bunch of folks!
    30,402
    Both the TF-100 and the K-2006 do not have lids for the cylinders (although there is an old pic on the website that shows them on the TF-100.....that will be changed this week.)
    The reason for that is so you Can't shake the cylinders. just swirl. It's tedious but it keeps the test accurate.
    May 2014
    Ohio
    75
    The real question is whether these TDS's are contagious. I don't want my pool to be the source.
    16' x 32' Hopper IG Vinyl | 19,000 Gal | Pentair Tegalus 60 Sand Filter | Pentair Challenger 3/4 hp Pump
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    This statement right here explains the extent of his knowledge.
    If you look at the ingredients on Liquid Chlorine and Bleach, the ingredients are exactly the same. Only the concentration is different.
    And just as a FYI or reminder, Chlorine itself is actually a gas. It has to be introduced into something to be usable in any form outside of a gas cylinder.
    "... liquid chlorine from pool store."
    Divin Dave,
    Apr 2014
    Shreveport,La
    17
    Well he did answer my question about not shaking the reagent....
    Jan 2013
    Houston, TX
    1,079
    Chuckle ... True.
    Sastocky's Avatar
    Mar 2013
    Jackson, Ohio
    22
    I recommend purchasing the Taylor Industries SpeedStir. Gets the best test every
    http://www.taylortechnologies.com/pr...ol-and-Spa.pdf
    Southern Ohio, 18'x36', 8'x3' deep, Vinyl, Hayward 1hp Super Pump, Hayward Sand Filter, Hayward AquaRite 25k SWG, 5-3'x8' Solar Panels, Hayward AquaSolar, Aqua Pro 137k Heat Pump
    Taylor K-2006, Taylor K-1766, Taylor SpeedStir, hth 6-Way with OTO
    Apr 2014
    Shreveport,La
    17
    I just ordered one last night after reading about them on one of the threads here!
