Thread: TFP Success
    tbone2's Avatar
    Apr 2014
    Hinckley, IL
    14
    TFP Success
    Didn't have the time while cleaning my mess of pool to post as I went, but still wanted to share the results. Figured people having issues would like to see that it's not impossible.
    Quick background on the pool to give everyone some perspective. Bought the home in November 2013. Got confirmation from one of the neighbors that no one has lived in the house for 4 summers and winter (pool not winterized). So all my lines had water in them through all these winters. Amazing there was only one broken pipe and that was above ground and an easy repair. Replaced the pump to be safe and fortunately the sand filter was fine. The pool had essentially been vandalized as well. Landscaping bricks, rocks, bottles, pool ladders, bike, camcorder, boxes of screws/nails and much more had been thrown into the pool. Top it off with 4 years of leaves and pine needles and I think you have an idea this was in bad shape.
    Check out some before photos:
    1902964_10101274121472479_431186404_n.jpg 10169328_10101288765959809_4782633118751764375_n.jpg 10346382_10101322990523509_4340170175298235623_n.jpg
    Note the wonderful pool cover the bank had put on. I saw from some other threads that this seems to be common practice for how HUD thinks a pool should be closed. Long story short removing the cover was a PITA. Took almost 6 hours to get it off.
    Fast forward to now:
    That's not dirt you see on the bottom. Unfortunately from all the metals thrown in the pool there's some pretty bad metal staining. Going to live with it for the summer and try an AA treatment in the fall sometime before I close. Other then the staining, the water is crystal clear. The whole process took about 30 days from that wonderful cover being removed to clear water. It took me longer as we went on two little long weekend trips and to be honest I got a little lazy. Always maintained the SLAM though, even if I wasn't scrubbing or actively working on it. I think I could have cleared it up in 10-15 days if I went at it 100%. I estimate about 60 bottles of 8.25% bleach was used. Can't imagine what chemicals a pool store would have had me put in though. Probably way more money than the $150 I spent on bleach.
    The TFP method does work for cleaning and maintaining even the worst of pools. Thanks for those that answered the few questions I did have. But most of my questions were answered in Pool School or by questions others have asked in the past. This is an amazing resource for anyone that stumbles across it and I now try to convince anyone I can with a pool to maintain their pool this way. Any newbies that stumble across this thread, just listen to what you read here. Doesn't matter what you've done in the past, what your neighbor says works or how your parents used to do it. If you choose the pool store over TFP.... good luck.
    THANKS TFP!!!
    18'x35' inground vinyl. ~26k Gallons
    1HP Hayward Super Pump. Jacuzzi 250L sand filter. No additional water features.
    Foreclosure pool, 3 years no use. Yes, that is a bike I got from the bottom.
    TFT-100 Test Kit
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: TFP Success
    Awesome post Tbone!
    I'm sure your post and experience will be very inspirational someday to someone who needs it the most!
    Keep us updated on how the metal staining turns out.
    Divin Dave,
    30,426
    Re: TFP Success
    tbone2,
    That's a great post! Thank you for using the TF-100 and Thank you for telling us of your success.
    PS - Anybody remember who wanted the nickname "tbone" desperately. I'll give you a hint.....smoothing!
