Results 1 to 10 of 10
Thread: Refilled 60% of our pool water 5 days ago
    Apr 2014
    San Carlos Mexico
    11
    Test results today are:
    Salt 3600
    PH 8.0
    TA 220/ppm
    CYA 60ppm
    FC 0
    Calcium Hardness 550ppm
    Pool Math suggests adding bleach and stabilizer... Since we've had so many issues I would like some input on those results.
    Thank you
    Becky
    12,600g, IG plaster, Sand Filter, Pentair 1.5HP, Eco-Matic SWG, Built 1/11. Polaris ATV
    30,414
    Re: Refilled 60% of our pool water 5 days ago
    Tell us what issues you have been having? How does your water look?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Are you sure pool math isn't telling you to add Muriatic Acid and Bleach?
    Your CYA level is a little low for a salt pool, but the low FC and high pH and TA are more worrisome at the moment.
    Apr 2014
    San Carlos Mexico
    11
    Thanks for replying...the pool looks clear but the test results worry me!? Yes you are correct Pool Math suggests Muratic Acid and Bleach. We have added the Muratic Acid, 27 oz. Soon after this we saw that the SWG cell cap has a crack and water was leaking, we have an old cap w/ a cell (that is no good). So the filter is running, no SWG for at least 2 weeks. We live in Mexico and have to get to the states to pick up a new generator. Any suggestions on how to get our pool in balance w/o the SWG would be appreciated.
    Gracias
    Becky
    Richard320's Avatar
    Jan 2010
    18,984
    Quote Originally Posted by blupomx View Post
    Thanks for replying...the pool looks clear but the test results worry me!? Yes you are correct Pool Math suggests Muratic Acid and Bleach. We have added the Muratic Acid, 27 oz. Soon after this we saw that the SWG cell cap has a crack and water was leaking, we have an old cap w/ a cell (that is no good). So we have the pump running, no SWG for at least 2 weeks. We live in Mexico and have to get to the states to pick up a new generator. Any suggestions on how to get our pool in balance w/o the SWG would be appreciated.
    Gracias
    Until the generator is running, bleach will keep it from turning green.
    Apr 2014
    San Carlos Mexico
    11
    Thank you, we will get the bleach in the pool...should I bother retesting the water in a few days?
    Becky
    Richard320's Avatar
    Jan 2010
    18,984
    You should be testing it every day. Chlorine is a consumable item, and you're no longer constantly feeding it with the Saltwater generator.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    ^^^ what richard said.
    Chlorine will burn off a bit every day. It's important to not let your FC drop below the minimum recommended level, You need to test it every day.
    since your SWG is broke, use the "with bleach" side of the chart
    http://www.troublefreepool.com/conte...mmended-levels
    Divin Dave,
    Apr 2014
    San Carlos Mexico
    11
    I am trying hard to understand all of this...will and the bleach and test for FC, CC and CYA everyday or do I need to do PH and TA also?
    Thank you for your help and patience It will all make sense with your help )
    Becky
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You just need to test for FC, CC and maybe pH daily (depending on how fast your pH tends to drift) CYA is a once every couple of months test for most people
