Thread: Inherited pool
    May 2014
    Oshawa Ontario
    2
    Inherited pool
    Hello! Bought a new house over the winter and I now have a 15" above ground pool with 6600 gallons of water. I've tested it and ph is 6.8, FC is 0, TA is 40 and CYA is 30-50.
    So which problem do I address first, TA, FC or pH?
    Thanks for any help you can offer!
    Jackie
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: Inherited pool
    You do not say if the water is clear. I would get the PH up to 7.2 and the focus on the FC/Slamming. CYA is OK. If you take FC above 10, PH testing will be useless until FC comes back down.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Jan 2013
    Houston, TX
    1,079
    Re: Inherited pool
    Welcome to TFP!
    Fist off what test kit are you using - pool stores are notoriously inaccurate. If you already have a recommended test kit and the numbers are from it:
    The pool math link above or in my signature will help with determining quantities.
    Ph first - wait 30 test to confirm then:
    FC - Pool math should show you a target of 3-7 and the appropratie volume of liquid chlorine (bleach).
    Feel free to post up what you are planning to put in and the volume and we will help you to confirm.
    Cheers!
    Chris
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    May 2014
    Oshawa Ontario
    2
    Re: Inherited pool
    The water is crystal clear right now. Pool actually looks great! I have a pretty inexpensive test kit from a hardware store. Is there a kit you'd recommend elwood58?
    Jan 2013
    Houston, TX
    1,079
    Re: Inherited pool
    Check this out for a comparison of test kits that have all of the components you will need: Test Kits Compared
    The link in my signature will take you to the site to order the TF-100.
