Thread: Easytouch/IC-40 Flow Indication Signal
    I have an Easytouch connected to an IC-40. I'm adding a Max-E-Therm heater this year, but the equipment pad is outside of the range of the pressure switch in the heater (Too high up the hill), so I need a flow switch.
    The IC-40 has a flow switch, and will be ~2 feet after the heater Does it send this signal back to the easy touch so that I can tie it back to the heater?
    _____________________
    15K IG Fiberglass
    IC40 + Easytouch + Superflow 1 HP 2 speed
    Sherlok 120, MaxETherm 200 HD Heater, Southeast Michigan
    Re: Easytouch/IC-40 Flow Indication Signal
    Yes, but. The EasyTouch will shutdown the pump, and therefor the heater, if it doesn't detect flow for several minutes. However, flow sensors aren't all that reliable, and the several minute delay is likely to cause problems.
    Is there a better alternative? The only way I see using the pressure sensor on the heater is to add an obstruction downstream of the heater (Maybe a short section of 1 inch pipe?)
    Normally you can just adjust the pressure sensor to the correct range and everything will be fine. What does the manual for the heater say about it?
    The manual says you can adjust to 5 feet above or 4 feet below. Outside of that use a flow switch
    I strongly suspect they want a flow switch that cuts off the heater right away.
    Hayward makes separate flow switch assemblies that you can buy as a replacement part for the AquaRite series.
