Thread: Replacing a Skimmer Weir
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    I needed a new skimmer weir. I had no idea what size or brand I needed. I didn't have any way to hold the weir in place. I found a weir with a spring loaded hinge that will stay in place, but it was too wide. I took a hack saw and cut the weir to size. I also cut a little off the spring so that the hinge would fit, too. It only took me 15 minutes to customize it to fit.
    I was also able to unclog my skimmer line using a garden hose... thanks to this website for helpful tips and giving me the confidence to attempt to fix my own pool problems.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: Replacing a Skimmer Weir
    Good job! Amazing what a little encouragement can do, and look at the savings!
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
