Thread: NEW Build Pump Size
    Mar 2014
    New Orleans
    2
    Question NEW Build Pump Size
    I'm building a gunite pool with attached spa. pool is 18 x 38 3.6ft to 6ft with 7x7 raised spa with 6 jets. pool will have 4 returns and 2 skimmers and main drains. I'm using all 2" pvc and pump is 12' from edge of pool. And do you need a blower on your jets.
    Re: NEW Build Pump Size
    Welcome to TFP!
    You need to know the design flow rate of the jets to determine the ideal pump size.
    A blower is not required. Almost all modern jets will draw in air even without a blower. However, with a blower you get more bubbles that you would without.
    Mar 2014
    New Orleans
    2
    Thanks The jets are 15 gpm. And is it better to have 2 different pumps or should i do it with just 1
