Results 1 to 9 of 9
Thread: Green mess help please
    Jul 2008
    Napa, CA
    5
    Ok..........so the holes are repaired, the liner is back were it belongs(or at least it is working were it is) The water levels are good enough to run the pump. I decieded to add "Shock" to the pool because I have 8 kids coming over this afternoon. THE POOL TURNED YELLOW GREEN!!!!! We dont have a great test kit, but here is what I have.
    Cholorine about 2.0
    PH 7.6
    ALK 200
    I went to the pool calculator that said I need to add both chlorine and acid to lower the ph.........can this be fixed in about ohhhh 3 hours.
    Rebecca
    AG 15X30 Doughboy 15,000 gl
    Pentair Clean and Clear Cartrigdge filter
    Power FLo Pump (We didnt buyu it so I dont know how big it is)
    revstriker's Avatar
    Apr 2008
    Texas
    117
    Re: Green mess help please
    Quote Originally Posted by sfbeca
    Cholorine about 2.0
    PH 7.6
    ALK 200
    Rebecca
    Why would it take 3 hours to add chlorine and acid?
    10K White Plaster Pool Built in 2007. Hayward Pump and DE Filter, Hayward Navigator, Liquidator (Removed due to issues), Solar Blanket, BBB user.
    Jul 2008
    Napa, CA
    5
    I wanted to know if it would not be green any more in that time? I have added both things to the pool as per the pool calculator, but dont know how long it takes to work on the color of the pool.
    revstriker's Avatar
    Apr 2008
    Texas
    117
    Ok, got it.
    Not sure how long it will take though. I guess it depends on what is causing the pool to be green. I can't really tell too much from the numbers you posted. Perhaps someone else might have a suggestion.
    Casey's Avatar
    SW PA
    10,461
    I doubt it will be fixed in 3 hours.
    Can you post pics so we can seeeeeee toooooooooooo?
    Jul 2008
    Napa, CA
    5
    Thanks guys.........but I called the local pool guy and he said because we are on a well, the cemicals interact with the iron in the water and that it just takes time to filter out. I had him test the water (he does it for free) and he said besides that I have lots of cholrine, everything else is good, so I just have to clean the filter every couple hours and wait it out.
    Appriciate all the input that comes from the people here.
    Thanks again
    revstriker's Avatar
    Apr 2008
    Texas
    117
    Did the pool guy give you the test results? If so, post them here.
    Jul 2008
    Napa, CA
    5
    I didnt write them down.............Just took his word that they were OK
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    He's in control of your pool. You can be in control of your pool too, if you want to learn how. Visit Pool School. Then when stuff like this happens, you'll know what to do and you won't have to pay a pb to fix it.
    Your PH is fine, you don't need acid for that. Your Alkalinity, however, is very high.
    If you have metals in your water, you need a metal sequesterant.
    Hope this helps
