Thread: Pool green and cloudy
    May 2014
    Marlboro, NJ
    1
    I am new to trouble free. My neighbor turned me on to this site and is very satisfied.
    My pool is a light green, cloudy after dumping 5 gal. of shock in the pool,
    My last readings were 3 for both free avail and total chlorine, PH 7.6, Tot Alk 100, 0 CYA, 200 Hardness
    I have a 33,000 vinyl pool with a heater. Never had this issue before. No nitrate concern.
    Before I make another trip to the pool store. Any suggestions?
    Thanks!
    Jan 2013
    Houston, TX
    1,079
    Re: Pool green and cloudy
    Welcome to TFP!
    What test kit are you using to get your results? CYA of 0 is suspect unless it is a brand new fill.
    Once we get that nailed down you will need to SLAM your pool:
    http://www.troublefreepool.com/conte...tain-shockingl
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Welcome!
    If your neighbor is a TFP adherant, ask him/her to doublecheck your CYA reading.
    If those are his/her readings, then it's fairly simple, though time-consuming. Add CYA granules to get to 30 in a sock set in the skimmer, and start the SLAM process.
    If it's eating chlorine like nobody's business and you had stabilizer on the water last year, then you may be one of the unfortunates who had it breakdown into ammonia. The cure is more bleach.
    See how these people did it and decide if you're willing to invest in the test kit and the time.
    http://www.troublefreepool.com/threa...ool-is-winning
    http://www.troublefreepool.com/threa...ark-Green-Pool
    http://www.troublefreepool.com/threa...st-give-up-Can
    First Time Shocking with Bleach
    Pretty black pool
    A little encouragement for those with algae and new to BBB
    Frog Filled Green Swamp to Oasis---Work in Progress!!!
    Before and After Pool Pics
    Before and after!
    A final picture set of how well the BBB method works!
